Compression
sr79
1979 Mercruiser 260 HP - I have 105 to 120 PSI compression. And the exhaust really smells bad, not oil but maybe un-burnt fuel. How low is too low for compression and does stinky exhaust mean bad valves?
Thanks,
sr79
Bt Doctur
Re: Compression
i woould think that 145+ would be a good engine. did you do the test correctly? Are these readings after squirting some oil into the cylinders
Re: Compression
Thanks,
sr79
Ayuh,.... Welcome Aboard,.... Nope,... Fuel smellin' exhaust says ya got a Carb problem,....
JustJason
Re: Compression
You need 100psi minimum across all the cylinders for it to run and idle properly. Your getting down there, and on your last legs. But it should still run.
84EdH
Re: Compression
sr79, how did you do the compression test?
engine warmed up?
throttle pushed all the way forward?
must turn engine over 4 or 5 revolutions also.
the readings, also, as stated squirt a teaspoon of engine oil down the spark plug hole and re-check the compression. if I goes up fair amount, it suggest rings are bad.
fuel smell in oil as Bondo said is probably a stuck float in the carb.
sr79
Re: Compression
engine warmed up?
I did another compression test this morning with throttle wide open and engine warm.
The new readings are: 1-120, 8-111, 4-111, 3-120, 6-108, 5-120, 7-118, 2-120
Note: Each cylinder would come up to 40 PSI +/- with 5 pulses and then to recorded reading after 15-20 pulses.
Next - I squirted a little oil in cylinders #1 and #2, No Change.
The engine is hard to start after setting a few days but then starts quick, idles and sounds good, well, OK.
The carb was recently gone through but still uses LOTS of gas. Spark plugs are black but not fuzzy.
Still need suggestions for fixing stinking exhaust, reduce gas consumption and get more power. Do I need to get a valve job, a complete overhaul, new carburetor or ?
Thanks,
sr79
old islander
Re: Compression
Black plugs would indicate a overly rich fuel condition...fuzzy or not. Follow bondos advise. Go through the carb again. And also verify your choke is working properly.
midcarolina
Re: Compression
If numbers didnt come up after squirting oil in the cylinders the next step I would do is a leak down test of each cylinder.....
That will help pinpoint ifn it's a valve issue.... I think you have two seperate issues #1 carb issue #2 compression
