ShoalSurvivor
- Aug 1, 2012
- 217
er... Alpha 1 gen II
Yesterday, had a hard time warming up. Idled ok, but when revved up, felt like she was going to stall. Eased back down then powered over it and she roared. Sounded like she had to push some sludge out, but she's clean and has been running fine. After that, no firing issues. Unusual and maybe unrelated, but the real problem:
About an hour out, my temp gauge shot up to 220. I was throttled down and took temps:
- starboard side exchanger too hot to touch. > 200 per ir gun.
- core at sender ~ 145-160
- thermostat surface ~ 120
- port side exchanger ~ 105
Gauge appears accurate. No alarms. Running at 2000rpm kept heat @ ~190
When I got home to flush salt water, she heated up really fast > 210 so I shut her down to prevent damage, but I still need to flush her out.
I suspect t-stat but am also suspecting water pump failure. I have a replacement impeller on hand and was going to start there....
Suggestions?
Suggestions?
