Welcome Guest - Sign Up today
No announcement yet.
Clear Braided PVC Hose instead of black rubber hose
  • Clear Braided PVC Hose instead of black rubber hose
    Could you use the Clear Braided PVC Hose for the incoming water to the thermostat as a way to make sure water is flowing? or is that some sort of safety issue that requires black rubber?
    Current:
    2004 Sea Ray 240 Select
    8.1L v8 496 Mercruiser - Bravo 1
    Previous:
    1989 Regal Medallion 185 18ft
    4.3L V6 Mercruiser - Alpha 1
    Re: Clear Braided PVC Hose instead of black rubber hose
    No, that's not a problem. As long as the size is right, and it's the same (or better) temperature rating.... Actually a good idea...
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      cool. some of my hoses are getting old so I think I will swap them out. Any tips for getting the water intake tube from the transom back on the bell housing? It actually slipped off while riding the boat causing a slight over heat. Main reason why boat is all torn down atm.
      Current:
      Previous:
      • #4
        Yeah, that one can be a bit difficult. You do need to pull the drive and then remove the hinge pins to get around behind the bell-housing. It's a PITA....
        BTW, don't understand the last part of your post....
        Main reason why boat is all torn down Automatic Teller Machine.... Can't make sense of this....
        Chris......
        • #5
          atm = At the moment. I pulled the drive and all due to the fact of the slight over heat. So re-did the water pump as in my other post and have to fix the water intake tube. Also putting a new carb on her. Hopefully she will run tip top when I move to the lake house in Georgia in about 12 days.
          Current:
          Previous:
          • #6
            And what temp does the incoming water actually get to ? Can't imagine it getting too much warmer than what the current lake temp would be correct ?
            • #7
              Mtsinner - I agree, maybe just slightly warmer due to outdrive temp. I believe the hose I mentioned has a maximum temp of around 150.
              Current:
              Previous:
              • #8
                My reference was because that hose lays on the top of the engine, and that DOES get hot!
                • #9
                  I threw in a 1' chunk of clear from the hardware store on my water intake line. I need to know what is going on there for "piece of mind". And I know what I used isn't heater hose rated but my logic says overall out drive temp and the water tube ported through the exhaust may raise it a few degrees but not very many with the flow it has...... hope my logic is sound !?
