Welcome Guest - Sign Up today
No announcement yet.
Heater install on a 2002 5.0 merc EFI
  • Heater install on a 2002 5.0 merc EFI
    I have a 2002 Four Winns (5.0 merc EFI) I have a heater to install, but I do not know where to connect the
    supply & return water hoses to. Can any one help with a diagram??
    Thanks
    Re: Heater install on a 2002 5.0 merc EFI
    Thanks
    Supply is from the manifold return is on the side of the water pump on the block.
    http://forums.iboats.com/boat-topics...ck-595506.html
    2013 Bayliner 255CR
    5.0MPI S/N:2A044802
    http://seawenchnc.blogspot.com
    • #3
      Here you go. I did a photo for you. Let me know if you get stuck. Click image for larger version
      2013 Bayliner 255CR
      5.0MPI S/N:2A044802
      • #4
        Thanks
        Ayuh,.... Welcome Aboard,..... agallant80 has got ya headed the Right way, complete with pictures,....
        Hot water Outa the intake, behind the t-stat, 'n returned to a port on the circulatin' water pump housin',..
        You'll need a 1/2" pipe to hose barb in the diameter of the heater ports, so 2 fittin's total,...
        Common sizes are 1/2" pipe to 1/2" barb, 1/2" pipe to 5/8" barb, 'n 1/2" pipe to 3/4" barb,...
        • #5
          Thanks !
