Have twin 5.7L, 1987, ser# of one is OB741607. Have tied several sources to obtain the correct timming and have found both 10deg. and 8deg. BTC would like to know the correct or best setting for these engines.
thanks.
They do that on purpose to keep us boaters on our toes. Make us do a little averages math and set our timing at 9. The real anus clencher is when you see a couple of manuals telling you to figure timing by purchasing tool J54827 which is a freakin slide rule. Anybody remember those?
thanks.
Question do you have efi or a carbed version...makes a difference...by the way the boy's are play'n here
Hey there Gunner, Just so your up to speed.... besides the 320 efi made between 1987-1989, Marine fuel injected as we know it today did not start until early 1993 with the 502 efi then progressed slowly with other engine models thereafter. grewvin1 serial number says he has a 1987 260 HP carbureted. Edit: Chris beat me to it.Question do you have efi or a carbed version...makes a difference...by the way the boy's are play'n here
First 350s with EFI came out in 1995... His are '87, so I would guess it's carbed (also by the serial number, it's carbed. )
I'm with Walt, when in doubt set it to 9*
Boatinfo - Mercruiser Service Manual nr. 9 - 1985-1988 - GM V8 Engines
If you are running pump gas (E10) set it to 8 degrees before... If you are running 90 octane ethanol free recreational fuel you can set it to 10 if you want to. However, the power difference is negligible. You are really better off leaving it at 8, that way if you have any water/fuel issues your less likely to have detonation problems.
