81 model 305 merc lower unit
bassboy2000
Im not going to fix this my self but need a little advice.
I have a 81 sea ray 197 with 225 305 when i bought the boat couple years back the lower unit had like a clacking noise to it not to loud. Guy told me gimbel bearing so i had him change it.
After that no noise unless u turned all the way hard one way or another, went like that for a season or 2. week before our wedding end of last year ( we rented a 16x80 houseboat to get married on) had a guy change lower unit fluid he found mostly water in it. I talked to him about the clacking noise we couldnt get it to do it atm go figure. He put some green syn oil in it.
So we was on the lake for a week ran around some etc but noticed boat was taking on some water not real bad and not sure if this is related.
If we stepped onto the swim deck u could see the green lower unit fluid in the water .
We dock the houseboat and i fired it up it died a time or 2 then after trying to start 3 4 th time it wouldnt turn the motor over it acted like something was locked up.
Heard no noises etc when trying to start it. the wheel wants to turn when trying to start . motor seems like its getting atleast one crank and stops prop spins by hand.
I think the boat may have wrong lower unit i know it was changed at one point. I d like to just have more info and order the parts online and have someone fix it. So if lower unit is bad what would be the one i need.
Stern drive sn on block 5901722
Block sn 5923379
5878013 sn for lower unit now
Thanks for any help
thumpar
Re: 81 model 305 merc lower unit
My guess is the drive is locked up. You can pull it pretty easily and try cranking the engine so see. If it turns out to be a bad drive just get an SEI. It will be cheaper than trying to fix the current drive. Check your bellows. That is probably the cause of the water coming in.
Arkyhunter46
It sounds like you have a few problems here. Water leaking into boat is most likely coming in from one of the boots. My guess is they all need to be replaced. Also sounds like you might need a seal kit on your outdrive, if gear oil is leaking out then you have seal damage at minimum. You are most likely looking at outdrive issues locking the motor up. As stated above, you're going to have to pull it off and see. Most outdrives are allergic to water in the oil and do not react well over an extended period of time. If the engine still does not turn over with the drive off then you need to pull the spark plugs and check for water in the cyls.
Before you spend a dime on parts invest in a service manual. There are a number of special tools required to service an outdrive and they will all be listed in the manual. At some point in time you will need to decide if the boat is worth putting a bunch of new parts into.
Block sn 5923379
Thanks for any help
Ayuh,..... Welcome Aboard,.... It sounds like you've got Alota problems goin' on,...
As noted, pullin' the drive off will let ya know whether the drive, or the motor is seized,...
Yer "Noise" sounds like the u-joints, but the drive has enough problems, a Whole New aftermarket drive would cover the u-joints,....
'n the water in the drive,....
'n if the drive is seized,...
The water comin' into the boat, could be the Bellows, either the driveshaft, or shift cable bellows,...
'course, if ya pull the drive, 'n the motor still don't turn, that'll have to be diagnosed to see why,...
Ya really shouldn't be buyin' Anything but some Mechanic's time, til it's Diagnosed to see exactly what needs replacin',..
Fishermark
That's just SOME of the possible areas of course. I would also wonder about the condition of the transom, etc. A lot of evaluating needs to be done before spending any money.
I am a little confused. You mention a Sea Ray and a house boat. Which are you working on? Or is it one and the same? :confused:
bassboy2000
I was typing all that up on my phone. we was on the houseboat for a week with our runabout in the water with us all week and that's when it all happened.
The boat is in great shape trans is solid and motor runs strong changed plugs the week of the lower unit oil and the plugs where older with only typical wear on them, no oil. We really like the boat its really wide or at least feels it and rides smooth. I figured i would have them change the boots with the lower unit.
From what i have seen its about 1200 to 1500 for a new lower unit. The lower unit on it now has a SN on it, but i am not sure that's the right one b/c of that clacking type noise. When i start looking them up i see there is different shaft sizes so i am not sure which one I need.
thumpar
Just pull the drive. It is easy. Put it in forward. Remove the trim rams at the drive and the 6 nuts. Pull it off. It weights around 75 pounds so be ready for it but I used to do it as a one man job all the time. I had it down to a 5 minute on and off.
bassboy2000
Thanks thumpar for the link that helps with me with my pontoon problem :). Why do i need to remove the lower unit ? I do not have the time to take on a project like this. If i have to pull it to find out which one i need to order i will.
Fishermark
You can buy a new lower unit for $795 from Sterndrive Engineering. Or by "lower unit" do you mean the entire out drive?
thumpar
I am not suggesting to remove the lower but the whole drive. At this point you don't know if it is the drive that is locked up for sure. Once you get it off you can test the engine to make sure that is not it. With the drive off you can measure the shaft also. At some point the drive will need to come off in this project so might as well do it now.
