Hi people.
I am running a 470 Mercruiser in a Savage Bluefin with built in fuel tanks.
Starting from the start,sorry if this is a bit long I will explain as much as possible to save a lot of questions and make thing easier for you people to answer. Thanking you in advance.
I had the boat in the water running perfect and it suddenly cut out during revs of around 4000 R.P.M with no warning at all,no misfire no surge nothing.
As it was the last time I was to have the boat out last season (Australian Season) I used my auxillary motor to get back to the ramp after no success of it starting after trying for a very short time. My guess was fuel problem after checking spark.
The boat sat on the trailer untouched for some months before I removed the carby.
Once I removed the carby I pulled it apart to find it was full of crap and decided to rekit it.
We have just entered a new season here in Australia.
I rekited the carby - Rochester 2BBl marine using genuine rochester kit.
Adjusted the float to specs - 11/16 Level & 1 9/32 Drop
I screwed both mixture screws all the way in,then backed them off two turns
I fitted the carby back to the engine put the muffs on the leg hit the key & bingo it started with no drama I let it idle for approx 5 minutes before turning it off thinking I would give the mixture screws a twink if needed when I know how it runs under load on the water.
The next day I filled both tanks with fuel ready to take it out on the water for the week end,checked all fluids etc as we do before going out and all was good being anxious as we do at the start of the season I fitted muffs again restarted engine to find no problem.
Boat sat on the trailer for three days untouched.
Ready to go out on the week end I wanted nothing to go wrong car hooked up I'm going to be fussy befor taking off towards the water and check fluids.
WOW... The engine was full off fuel in the sump,more fuel than oil in the sump.
I drained approx 33 litres out of the sump plug fuel obviously up into the block it had syphoned itself from the tanks while sitting.
Now notes to take into consideration
NO it does not have an electric fuel pump.
No the tank vents are not blocked
NO my carby DOES NOT have check balls it is the model carby released from factory WITHOUT CHECK BALLS NO CHECK BALLS REQUIRED . In doubt so was I & researched to find not all Rochester 2BBl had checkballs FROM NEW
This one has me completely lost suggestions please
Mark
Mark
