I have a 1977 Glastron with a 140 HP 4 cylinder Mercruiser. Oil has been leaking out of my PCV tube and creating quite a mess on my carb and down the engine block. I have been hearing a clacking sound which I believe is coming from the valves and is only heard under a load or at full throttle. I did a compression test and found that it is very poor 110,70,75,40 (dry) and 125,95,90,45 after squirting oil into the cylinders prior to the test. Both tests were performed while the engine was cold. I recently read a post describing that a person had a blown head gasket which was causing their low compression and replacing it solved their issue... I know I have much more than just low compression going on here, but could all of these issues described above be caused by a blown head gasket? or am I looking at more extensive damage internally? If i have to do a full rebuild would it be more cost effective to do the work or just junk it and buy a new/rebuilt engine? I do pretty well around the garage and could tackle a rebuild but have never done a full rebuild before. Any help or advice would be much appreciated.
Thanks!
Jamie
Thanks!
Jamie
