Hi all,
Newby here. I just bought a '97 Sylvan 178 with a 3.0 Mercruiser. The temp gauge is not working. Water seems to be circulating ok. When I hook up the muffs and run it, warm water comes out of the exhaust post on the right side of the lower unit. I am new to boats, but I am somewhat mechanically inclined. I pulled the thermostat out and tested it, it seems to be opening and closing ok (it was closed when i took it out). I'm not sure if the next suspect should be the sending unit, the gauge, or somewhere in between. Any help on my next step would be appreciated.
Thanks
Thanks
