Power is weak coming out of the hole. Once it planes and rpm's get to 3500 there is a strong power surge to WOT and it appears to be running at full power. It starts and idles perfectly. It revs just fine also when not under load. So the problem is weak power in the mid range under load.
I have been using mostly gas from gas stations (likely with ethanol). I put 2 cans of Seafoam in it with about 25 gallons of gas and ran it to almost empty. Then filled it with marine gas (no ethanol). It runs a bit stronger but has same problem.
Any suggestions?
Any suggestions?
