natureschild88
- Jul 10, 2013
- 40
I have a 1990 Mercruiser 4.3L V6 (2 barrel Mercarb) that has a fast idle. Sorry, no serial number on hand. At start up it revs at 900 rpm and after running for a minute it goes up to 11 or 1200 rpm. I recently rebuilt the top half of the carb (accelerator pump, float, cleaned out ports and jets). Before I cleaned out the ports, half of them were clogged shut. I had the idle dialed in at 650 rpm after I rebuilt the top half of the carb.
The idle has slowly gotten faster and faster in the past month and a half (I've taken it out once a week). I tried adjusting the idle screw, but it doesn't change anything. I had to pull the screw all the way out, and the idle finally dropped to 500 rpm then died. I don't think there is a vacuum leak, as there are no hoses that go to the carb.
I can get it to idle at 700 rpm by covering the idle screw hole half way with my thumb, and it jumps back up to 1000 when i put the idle screw in without even starting the threads. I took apart the top half of the carb and cleaned out all the jets again. I shot a bunch of carb cleaner into the hole for the idle screw and it made no difference.
Any ideas as to what can be causing this?
