hazelheckler
- Apr 18, 2012
- 14
1978 mercruiser 228 overheats.
new sea water pump, cleaned manifolds and exhaust elbows, what is the water flow rate incoming from the sea water pump at idle? , at higher speeds?
I checked it at the hose coming into the power steering cooler and it is about 1.5 quarts in 15 seconds at idle, is this enough? my books don't say what the flow should be,,, Thanks
