I have a '98 mecruiser 5.0 carb I/O... Fuel pump isn't coming on. Checked fuel pump by applying 12v directly to it and it seems fine. I can actually run the engine if I do this... So then I check the voltage on the other end of the pigtail (purple w/ yellow wire plus ground) and while cranking I get anywhere from 9.5-11.5v fluctuating, which doesn't seem to want to run the fuel pump!!! I have removed the purple w/ yellow wire from the starter and cleaned it, I have also jumped the oil pressure switch (purple to purple w/ yellow) and neither of these have helped. Already replace fuel pump and backflow valve in tank.
Also, had the alternator/generator replaced at the start of the season....maybe I should check the purple wire from alternator to ground as this would be the primary supply voltage to the fuel pump during cranking...yes?
One more question...is there any possibility that the alarm warning circuit could impact this problem? (It may be coincidental but once it was all previously running it seems that things eventually got screwed up
once the oil warning wire (tan) was reconnected)?
Next steps in the diagnosis?
