Welcome Guest - Sign Up today
No announcement yet.
Oil not coming to rockers when priming
  • Oil not coming to rockers when priming
    Hello!
    When I rebuild an engine, I always have the habit of manually turning the pump for priming and oil covering the engine throughout.
    For that, I remove the distributor and use a home made tool to a drill. I turn it until the oil reaches the rocker area.
    I never rebuilt the 4.3L chevy engine, so I don't have experience with this engine. Other than euro ones, I rebuilt the big Jeep ones, the Inline sixes and the AMC 5.9L v8.
    When I finished the rebuild of the boats 4.3l also tried the priming trick, but the oil didn't come to the top of the engine.
    I could make flow the oil, the drill felt the drag as the pump primed, but never arrived to the valve train area.
    Looking through the holes on the heads there was plenty of oil on the tappets area and on the cam.
    I didn't service the pump. The engine was good enough I didn't thought that was necessary.
    Then I jumped the starter and made the engine turn for a minute or so (without the plugs or gas), but oil didn't came to the rockers.
    Re: Oil not coming to rockers when priming
    Originally posted by Sergi View Post
    Hello!
    Ayuh,.... It's the pumpin' action of the lifters that pumps oil to the rockers, not the pressure from the oil pump,...
    Sounds normal to Me,...
    • #3
      Ok, Thanks Bond-o. We'll see soon if we get the lube when I first start that engine. Other than that, he was blowing nice through all the plugs holes. It was rebuilt becouse a low pressure at nrs 2 and 4.
      • #4
        Ayuh,.... Crank it over on the starter without the spark plugs in it,.....
        • #5
          Yes, that was what I've done when I saw the oil wasn't coming to the rockers. At least cranked for a minute or two (or more) until wires started to get hot. But no oil. The rest of the engine had plenty of it, even it came through the distro hole. Uhmm....
          • #6
            When you cranked it with the plugs out, you did have the dizzy installed right? Just making sure.
            • #7
              There are two types/styles of distrubutors, the tool does not tend to work with vortech intakes because it has to seal the valley to produce pressure. If you use an old distrubutor they tend to seal a lot better than the tool
              • #8
                Uhmmmm... Not sure. I guess not.
                • #9
                  My tool doesn't have any seal at all. It's only a rod inside a protecting tube with another tube sleeve at the end for not coming out the pump tip.
                  Does make sense. That's the reason the distributor gasket was so robust and the claw clamped so well. In AMC engines/Mopar that gasket seems merely presential and the clamp it's flimsy.
                  But, if that system requires to have pressure at the valley, means that you can't inspect without valve covers or even without the oil cap on? The valley is connected to the top of the heads through the pushrod holes. What about the PCVs?
                  • #10
                    It must be installed to drive the oil pump from the cam, which should pump up your lifters and oil should flow thru pushrods and out the holes in rockers. You can also watch the oil pressure gauge once you see pressure, you should get oil at the rockers.
                    • #11
                      Oh, yes I should have it replaced before the crank, excuse me.
                      In fact, I somewhat remember looking at the turning rotor entranced.
                      I must have installed the distributor by the time. I did like this for not to loose TDC and timing.
                      EHEHEHEH...
                      • #12
                        you need a full dist body with the priming rod. I had ground away the teeth from the gear for mine.
                        NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
                        • #13
                          Thanks Bt, I've got a spare dist, but at the time didn't like the idea of grounding the teeth on it. I tried to remove the pinion and flip it, with no success. It was seized. May I try harder.
