Merc 5.0L MPI, serial # OWO18920
So I'm getting a relatively minor squeal at mid-range rpm (1200 or so) and higher. It sounds like its coming from the circ. pump. Idler pulley, tensioner pulley, and PS pump have been replaced in the last 2 months, and the raw water pump replaced last year. The sound is definitely not coming form the alternator, so it seems like that circ pump is all that's left.
I removed the belt and turned the circ pump manually and it makes a very slight noise. It turns easily and there is no grinding or wiggle, but there is a very slight noise...
What do I do? Can I do more diagnostic that this? Just go ahead and replace it (it's about $80- $100 for the part)?
Has anybody replaced on of these? Is it pretty straightforward? Any tips or advice before diving in? Cautions???
Thanks,
-Nick
Thanks,
-Nick
