On my 1988 Cheeta 4.3 I have checked the shift cable and it is 6 and 1\8 inches from center of brass barrel to center of cable hole. Is this a problem? I know the manual says 6 inches. The brass barrel is pinned and not adjustable per manual.
I have adjusted the remote cable to excactly to match the cable and shift plate .
It will go in gear manualy forward and reverse by moving the cable by hand.
Out of the water with muffs on and the engine running and the throttle disconnected it will go in gear just fine,
Fwd and Rev.
When I connect the throttle it will not go in either one and the engine speeds up.
Is this a throttle problem and how can I adjust it or is it something else?
This is a new Sterndrive upper unit.
I was looking at brass shift rod and it has a tie wrap on it. Is this correct? I also do not see a washer like the Merc had.
Is this correct also?
I have tried to talk to Sterndrive Eng but can get no call back.
Thanks for any help
Fwd and Rev.
Thanks for any help
