I took engine out disassembled everything and replaced a piston, main-rod bearings, and rings. I labeled everything and put back like it came apart (did not take cam or crank gear off) marked and reinstalled each lifter and push rods in original places etc etc But....
I forgot to mark the exact clock time of the rotor button exactly (brain fart was thinking it would only go 2 ways right or 180 out uggh) I have the distributor rotation clocked to the factory scribe mark and the rotor button is pointing towards the No. 1 spark wire (eye ball accuracy). I would think this is close enough to crank but am getting some coughing back through the carb like timing is off. Or could it be rockers are too loose. I backed off rockers and planned on adjusting them once I got it cranked and warmed up (lifters pumped up).
How do I check the distributor is on the original gear tooth of cam for initial timing. About how many deg for a gear tooth? Would it be obviously off or could it be off by a tooth and I am just missing it. Is it time for a timing light? Will a timing light work while cranking with starter?
