I have a 1988 celebrity with a merc 5.0 and alpha one drive.So the problem is no water getting to the block or manifolds.I will start from last season, towards the end of last season I installed a new impeller and housing, seemed like she was running a little warmer than normal so I figured it was a good idea to change the impeller,after the change everything worked great,no issues and it run much cooler.When I put the boat in storage, heated shop,I flushed everything out,changed the engine oil and put stabilizer in the fuel and ran it through the carb,the very last thing I did was pull the thermostat housing and filled the block full of antifreeze just to try and prevent corrosion.Now it's time to get ready for another boating season,changed oil in drive cleaned up thermostat housing and installed new thermostat and sleeve,checked all the hoses and clamps everything looked good,hooked up the muffs,turned on the water,then tried to start the engine,it took a couple of tries but started and ran great rite away.Next I checked for water coming from the exhaust ports in the drive,lots of water and looked like the antifreeze was coming out,also the port at the bottom of the drive by the oil drain plug had lots of water coming out,a steady stream.I then headed back to the controls everything was looking good then I noticed the temp gauge slowly creeping up,I thought maybe the thermostat needed to get a little bit hotter to make it open,but the gauge kept on going,no numbers on my gauge,it's digital,it went to one line from the top so I shut her down and let it cool.My first thought was a faulty thermostat so I removed it.When I took the hoses off the thermostat housing I noticed that the hose coming from the drive which I believe is coming from the sea pump to the thermostat housing then the water pump was dry,not even damp.So I'm thinking that the problem is the impeller but I can't figure out how I am getting water through the exhaust ports in the drive without having water in the block or manifolds,and it gets even more confusing,when I open the drain cocks on the manifolds and block I get antifreeze.Could it be that the block is air locked or something,very confused and I would hate to pull the drive apart only to find no issues with the impeller,any suggestions or has any one had this trouble before?
