Chevy 4.3 conversion
bertvh
I have a chevy 4.3 vortec out of a 95 chevy truck. I have a blown 1998 4.3 Mercrusier with a cracked block. Can I transfer all the Mercrusier parts, carb,intake,started,ect... and drop it in my boat. Has anyone done this successfully? Are the heads different?
tpenfield
Re: Chevy 4.3 conversion
Yes, it is one of the more frequently asked questions. So, there should be some threads that you can refer to for additional guidance.
Ayuh,.... Welcome Aboard,... sure ya can,...
But,... the '95 is Vortec in name only,... Vortec heads came out in '96,....
So the heads Are different, along with the intake manifold,...
Volphin
Yep. So if your old heads are ok, send them off for a valve job and install them on your donor engine. They are a superior design.
bertvh
The heads on my donor Mercrusier are cracked. Can I use the heads off the truck motor??? I will mill them down and pressure test them.
Volphin
Sure you can. But it would be wiser to go get some other Vortec heads from a junkyard and have those refurbished. They can be had for $50 a head, sometimes $75 for a pair.
Ayuh,.... With a Different Intake manifold ya can,...
The bolt pattern changed with the heads in '96,...
Volphin
Yep. and the truck intake mani will not work.
