Hi all and thanks in advance for any help and advice. I have a 1985 Bayliner 2550 Ciera Designer's Edition that I put a 350 engine in coupled to a mercruiser 260 outdrive. The engine has a Pertronix ignitor in it, Pertronix Flame thrower coil. Carter 4 BBL carb(9781s 1875). Closed cooling system. Compression on all cylinders is 125-160. Which according to Mercruiser service bulletin is good. I bought a 16in dia 16 pitch prop from the local prop shop based on their recommendation. The problem that I am having is I can only get 3500 RPM at WOT doing 26 MPH(2 adults, 2 children, 50gallons of fuel, 20 gals of fresh water, empty holding tank). From what I have read on other forums is that that is about what cruise RPM should be. Things that I have done:
1 Read the Adults Only post for low RPM at WOT
2 Changed fuel water separator
3 Rebuilt Carb
4 verified no air bubbles in boat side fuel lines, added 60 gals fresh fuel to 25 gals of old fuel
5 Adjusted Timing to about 30 degrees advance at 3000RPM in neutral?? using timing light with advance feature but I am not certain if I am doing this correctly.
It will not go beyond 3500 RPM as if there is a mechanical stop. It is slow to get on plane. If I drop below the 26mph the boat drops off plane. Temperature climbs to about 220-230 but the new gauge is suspect. When I drop down off plane temp stays at 200 but infrared temp says temp at probe is about 160 ish. The boat is in the marina so I am limited to checking stuff in the boat. Thanks again for any help.
3 Rebuilt Carb
