Re: Alpha 1 lower unit install
Make sure the lower is in fwd by holding the shift arm insert and turning the prop shaft counter clockwise till you feel it lock.Shift arm on the upper should be straight ahead.Put them together and if they wont mate up ,move the prop shaft counter clockwise a tad.I have had an easier time doing this on my bench with the upper ,upside down.
