Part II Resevoir, grinding noise after I topped up the Power Steering Resevoir?
Thanks, now for part II.... I added some Dexron III ATF fluid to the resevoir as it was a little low. Took the boat out for a good hour or so, anchored for another 5 hours, and then came back in. When I arrived back and slowed down, I could hear what sounded like a grinding/humming type noise, when I turned the wheel, when it was straight no problem, but turning it now results in this noise? It turns just as easy as it did before, but this noise is new Any ideas as too what it could be? It was new Transmission fluid that I just bought, and it was low, but there was still some in the resevoir.
