Welcome Guest - Sign Up today
No announcement yet.
jb weld on trim fitting?
  • jb weld on trim fitting?
    I made my first really stupid repair mistake on my MC 120 outdrive. After 5-6 hours of trying to thread the trim hose into the connecting block, I gave up and just reefed it down cross-threaded, hoping it would hold. It didn't hold. Then I tried to re-tap it. Now it wobbles in the threads. I bought a new connecting block, but the trouble is, I can't get to the lock nut inside the transom (no way, no how) to replace the old one. My marine mechanic friend tells me there is no way it comes out with the motor still in.
    How silly is it to think I can slap some JB Weld or Marine Tex around the threads and fitting? I really don't want to pull the motor for this if a simple fix has a decent chance of holding.Click image for larger version
    Re: jb weld on trim fitting?
    Not a snow balls chance in .............. well, let's just say it won't work.
    The engines aren't that hard to get out. If you have a way to lift it, an hour at most and it's out.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Very silly...
      1976 Rogers Custom Boats 18' "Bonneville" W/ Chevy 454/ Berkeley 12JC
      Care Taker of 1976 Glastron V-184 Crestflight W/ Volvo 170B/280 I.O.
      & 1969 Starcraft W/ 1956 Evinrude 7.5hp Fleetwin.
      • #4
        I was afraid of that. Looking like a full resto, if I'm gonna hafta remove the heart anyway.
        Thanks, Don.
        • #5
          Looks like your old fitting is brass, you just might be able to braze a fitting into the stripped hole.
          1999 Powerquest 260 legend
          502 mpi
          B1
          • #6
            Ever try to braze stainless steel fitting and line to a brass fitting? In tight quarters with oily parts?
            Don S.
            • #7
              Forget the stainless and line, get a brass brake line fitting, 1/8 inch by the looks of it. Who pulls motors in an hour? Takes me that long to wiggle myself in there with some wrenches
              502 mpi
              B1
              • #8
                Ayuh,... Yer right, that's pretty slow.....
                If ya can get to it, that brass fitting oughta come out with a 12 point socket...
                • #9
                  Just kinda thinking out loud here... But can you drill it out larger, tap it, and use an adapter back down to original size?
                  iboats: You Can Do It. We can help!
                  Regards,
                  Kick Back
                  Building The Boat That No One Makes
                  The "81 Sea Ray 26 Sedan Bridge I/O to OB Conversion/Restore (Pics)
                  " Thread
                  https://forums.iboats.com/showthread.php?t=520100
                  • #10
                    Who takes an hour to pull the motor? 20-30 min tops!
                    When will people learn that impellers require regular
                    replacement and are not drive it till it pukes items?
                    1984 Regal Medallion 195
                    3.8 V-6 with the dreaded
                    OMC Stringer Drive.
                    2003 Avalanche w/Hypertech
                    If it ain't fixable - don't break it!
                    • #11
                      Not everyone starts the timer after they get the boat in place, and the ladder set up, and the tools on the boat, trouble light hooked up, engine cover off and out of the way, seats out of the way, nor do they have air tools. And not all engines are that easy to get to.
                      That's what gets people into trouble with a shops quote. That quote has go cover the time needed to do the complete job.
                      Don S.
                      • #12
                        amen...
                        thats why most shops quote an 8 hour flat rate for removal/install and testing for a motor pull
                        ive pulled motors that took 30 mins to unhook and pull, after 3 hours of removing, seats, bolsters, 200 lb engine hatches, etc...
                        to o.p. : search the forum for engine removal, you will find some interesting ways folks have pulled motors here, keep in mind safety first
                        and this is a great time to do some tlc on other areas/parts that are difficult or impossible to reach with the motor in place
                        • #13
                          Originally posted by dubs283
                          Sometimes when people try to save a penny, they end up spending a dollar.
                          It is best to fully understand how to properly operate, inspect, troubleshoot and repair your equipment
                          Man I love this... Especially the first part. So many come here looking for the 'cheap' way of doing a job, and then get all bent out of shape when they get told to do it the right way the first time....
                          xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                          The world takes on a whole new perspective when viewed from 100’ below.
                          1972 Bertram ‘Bahia Mar’ 20
                          2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
                          (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
                          • #14
                            would a heli coil work for him here Don ?
                            1980 Wellcraft 170 Sport
                            470 mercruiser 170 H.P.
                            FAST FAST FAST
                            • #15
                              When they tell me (the customer worked on it) i just feel like going home
                              If you can read this thank a teacher.If you can read it in english THANK A VETERAN
