Ok Guys,
i need some advice. I have a merc 140 with an alpha one out drive 1/98 gear ratio. When I bought the boat I heard growing noises from the out drive so I knew it had to be repaired so I went ahead and replaced the upper gear set on the out drive. well now it seems like it takes a min for the water pump to to start pumping. also I hear noises from the out close to the transom. not sure if it was there before. the grawing form the out out drive is all heard.
Thanks in advance
Thanks in advance
