I just replaced the trim sender and limit switch on my 7.4/Bravo and I am trying to adjust the sender. With outdrive all the way in when I am rotating the sender I reach a point where the guage moves from all the way up to all the way down. I set the sender at this point then when I trim up the guage does not respond untill the outdrive is trimmed out about 25% of the way. Then the trim guage pegs in the next few inches of trim up .When I rotate the sender to adjust there is no place where I get a reading on the guage that is not all the way up or all the way down. If I move the sender at all from the point where the guage shows all the way down the guage jumps to all the way up.
Ran the boat and the guage does not come off all the way down till the outdrive is past the operating range then it pegs almost immediately.
Do I have a guage problem? Is there a way to test?
