Welcome Guest - Sign Up today
  • Dear Community Members,
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change. What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 9/30/2020! The whole transition should take 24-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
No announcement yet.
Changing the Alternator Belt on 3.0L mercruiser
This topic is closed.
  • Changing the Alternator Belt on 3.0L mercruiser
    I had the alternator belt shred on me the other day. I went to several sites to see if there was anything I needed to know about changing them since the front pully is damn near touching the front engine mount. The suggestion was to hook up a engine lift and raise the motor to change the belt. Are you kidding me? I called a friend of mine who works on boat engines and asked him what would be the easiest way. He looked at it and said to take the front pully off. I Changed the belt in 15min. I got a replacement from Pep boys by taking the old belt up there to try and match it to a new one, but Does anyone have the part numbers or where to get them for the belts needed to run the alternator and the power steering on my 98 3.0L? Would be appreciated.
    Re: Changing the Alternator Belt on 3.0L mercruiser
    how did you get the belt off with out removeing part of the front motor mount it traps it???most people put in a spare belt when changeing it and tie it out of the wayand auto store is a good way if you can match up the belt just keep buying the same one if it fitstommays
    If a dirty bottom slows you down what do think it does to your BOAT
    1970 Cal 29 Sea Fever
    http://cal29seafever.blogspot.com/
    1981 J24 Tangent 2930
    http://s565.photobucket.com/albums/s...%20for%20sale/
    Tommays
    Northport Ny
    • #3
      I did remover the motor mount. Sorry for not saying that. Not a bad idea of putting in the spare belt.
      • #4
        Did you get the parts number for the belt???
        • #5
          I did get the part number for the belt. Did you need it?
          • #6
            Yes. If your boat engine is the same as mine. I have a I/O 3.0l mercruiser with Alpha 1 outdrive. It would be a good reference if ever I should need to replace the belt. Thanks
            • #7
              Ditto Big Poppa G, I could use the number also, as My Carver has twin 140's. Thanks!!
              • #8
                I'll post it tonight when I get home. The number is in my garage. Remember its for the Alternator belt.
                • #9
                  beezee28,interceptorHere is the information on the alternator belt. I bought it at PEP BOYS.15395DYNAFLEXHeavy Duty Automotive V-BeltBy DAYCOCost: $8.39Hope it helps.
                  • #10
                    Hi allIf the 3.0 is anything like the 3.7 with a little manipulation you can actually get the belt on without taking off anything in about 5 to 10 mins... I just pushed the belt down on the sides of the pulley and then pulled the belt down on both sides and it went through with no damage to the belt..few scuffs but no fraying or anything significant...
                    • #11
                      Tried as hard as I could without damage but the front pully is too close to the front engine mount. Removing the pully was the only way to get enough clearance. At least on the 3.0.
                      • #12
                        Bummer...that does'nt sound fun at all! The clearance on mine is narrower than the belt but I was able to at least get it through....The worst part was that the belt that fit mine was $18.
                        • #13
                          You win on one........you lose on the other.
                          • #14
                            What is involved with removing the engine mount enough to get the belt in place, are special tools required, etc?
                            Daryl
                            • #15
                              OLD Thread
                              October 2004
                              If you have a question, start a new thread, don't just tack onto an old thread or ask it on someone elses thread.
                              Don S.
                              Please, no PM's (Private Messages) regarding boat/engine problems.
                              That is what the forums are for.
                              Only forum/moderator issues will be answered in PM's.
