haulnazz15
- Mar 9, 2009
- 3,720
I've got a quick question. I have an exhaust leak on the port side exhaust manifold, which is a new manifold to go along with the new 351w I put in there last summer. I used the exhaust gaskets that came with the center-riser conversion kit from ebasicpower. The leak was there from the beginning, but I wanted to put a few hours of run time on the new engine before I fixed the small exhaust leak.
Now, to my question: do normal automotive gaskets work for this purpose, or do I need to go back and order the gasket from a marine store? If the automotive ones work just as well (especially in 1-piece form), is there a reason I should choose one gasket material over another?
Note: I did search for about 30 minutes on this and came up with varying answers. To me, it seems like exhaust-only is coming out at that point, so I see no reason it should be a marine-only part.
