Hi I have a 1990 scand dynamic 7.100 with a volvo aq271 and a dp290 the tillt and trim wont go up or down the pump is running ok but noticed and oil trace from behind the boat about two weeks ago and had a look for an oil leak but found nothing went to take my boat out today and found the trim and tilt would not work sounds like there is no hydrolic oil in the system can you tell me where the resovior is? the pump is an early type
regards chezz1309
regards chezz1309
