Boater1981
- May 31, 2010
- 2
I finally got my Sylvan in the water this weekend after a $600 service bill. I put it in the water, it fires up and sounds good at idle. I give the boat some throttle and starts to make a load clattering sound similar to a diesel engine. The motor had no power beyond 2000 rpm and the last 1/4 throttle had no effect on power. I checked the plug wire configuration, made sure it had good fuel, cleaned the spark arrestor, spray cleaned the carb, tried messing with the timing (back yard mechanic next door gave me a hand). But at the end of the day it only made it worse.
When the engine is cold it would idle good but as it was revved up and brought back down it would start dieseling at idle.
Any ideas out there?
Thanks,
Thanks,
