Re: 5.7 Mercruiser water in cylinders
If I was a marine mechanic, and I made all of my money on boat repair, I would tell you that your boat needs a new engine as well. If the oil is still clean, and there is no water in it, then it is unlikely that the block is cracked. What you have described so far, with the water in the cylinders sounds a lot like hydralock, and the risers are toast like magster65 said. There have been numerous discussions in this forum about it. Do you have a mechanically inclined friend whom can maybe go a take a look at the engine with you?<br />If it were me, I could never afford to have a marine mechanic install a new motor, so I would exhaust every possible option before resorting to a costly re-engine. Remember $5000 is just the tip of the iceberg. Labor is going to be the killer. In fact, the engine purchase price might be the cheapest part of the whole deal.<br />Another thing, if the block was cracked, do you have any idea how it could of happened. Usually a block cracks when the boat is not winterized properly and the water inside freezes and expands. Did that happen in your case? If so, did you have the same mechanics, that are now trying to sell you a new motor, winterize your boat for you? If so, I would say the damage is their fault, and they are liable to put in the new engine for you. Just a thought.
