Welcome Guest - Sign Up today
No announcement yet.
Permatex #2
  • Permatex #2
    I used this to assemble the impeller housings on a stringer.
    Since this is what the repair book said to use, I did. Anyone have an idea how to seperate the two pieces? They just don't pull apart and am hesitant to use more force. [vise,etc]
    Re: Permatex #2
    Razor blade of some sort. Utility knife, box cutter etc. What's a stringer in this context?
    When goals have no clear focus, neither will the actions of the people trying to achieve them
    • #3
      Re: Permatex #2
      Sorry, stringer is the type of outdrive. I've tried the razor knife thing but the pieces fit so tight that it doesn't work.
      • #4
        Re: Permatex #2
        Take the blade (utility) out of the handle and try tapping with a hammer. Carefully, straight in, of course. May need more than one and watch your eyes, and wear gloves.
        • #5
          Re: Permatex #2
          Heat up the junction. It'll soften with heat. Failing that, I'm pretty sure alcohol dissolves it.
          • #6
            Re: Permatex #2
            Permatex #2 is great stuff! I have been using it for years.
            Warm it up gently - a heat gun would be good - just warm to touch and the two parts should twist apart SLOWLY. I haven't found anything yet that will dissolve Permatex.
            • #7
              Re: Permatex #2
              !0% ethanol gasoline dissolves it, slowly.
              • #8
                Re: Permatex #2
                Piano wire
                just because you found it that way does not mean it is supposed to be that way.
                • #9
                  Re: Permatex #2
                  Thanks for all the replies. I'll let ya know if I get it apart.
