I have been having this intermittent problem with my Merc 140. Once in a while when i put the coals to her it will bog. I redid the ignition and the problem still is happening. I am about to rebuild the carb but i am thinking it may be something else. Today at the lake i filled the boat with 92 premium gas almost to the top. The boat ran absolutely perfect until i got down to between 1/4 and 1/2 tank. Then the bog reappeared. Why when full is the boat running that much better. When it gets down on fuel the idle is worse and the bog returns. I have only tried filling it once so i am not sure if it is coincidence. Any ideas ?
