87 22ft. searay 350 motor ,when i,m idling down the cove the sterring wanders ,i correct it then it does it the other way ,the boat has 235 hours on it . can the sterring be worn out or is there ajustment on the play in it.
I just had an episode where my upper helm started leaking so it allowed air in the system.<br /><br />I lost steering both above and below, not very fun and very expensive becuase the helms were to old to rebuild the newer ones can be..<br /><br />Thanks<br /><br />Darren
Yep...Trent is right on the money. My 18 footer powered by MerCruiser does the same thing. There was a lot of discussion on this topic some months ago. You do want to insure all your steering linkages are in good order, however, what you describe is very normal.<br /><br />Walt
