Re: mercruiser outdrive shift problem
O K here is what happens, I did a little reading in a manual. I think the shift cable did break. The frayed cable might explain why it became so difficult to shift. I did check the cable between the helm and the stern and it is O K. When I would turn the motor off and put the throttle in the neutral position to start the motor the outdrive would also be in neutral, after I started the motor and put it in forward I could move the throttle/shift lever to neutral and reverse position with no problem, but the drive would stay in forward. Is there any thing else that would cause it to be hard to shift. And how hard is it to change a shift cable, I am a pretty good backyard mechanic, but not experienced in mercruiser. And thank you very much for the replies.
