Having a voltage issue with this 454. I have a brand new marine alternator. It is the 5 wire - two exciter wires pigtails and three wire bolt on.
The voltage gauge is pulling a negative voltage on revving the motor. The motor will not stay running when disconnecting the battery.
Can I get a schematic of the wiring of this alternator (more specifically wire colors and which studs they attach to) for this?
Or, is it something else? It reads 12 volts before starting. When at idle it reads 12 volts - I think it should be closer to 13-14 volts when idleing and maybe close to 14.5 at higher rpm's...It draws down to around 9-10 volts when revving the motor.
I am using a good hot, new optimum gel battery.
Any ideas?
Thanks.
Chuck
Any ideas?
Thanks.
Chuck
