00 mercruiser 5.7. I got a a back fire coming from the carb intermittenly not all the time and mostly when trying to be pushed hard (WOT). It will rev up fine in neutral when sitting, but then when in gear does not want to move. Also when it does start to pick up i cant get it passed 3K RPM. I was wondering if bad plug wires would have any effect on this? I coated them with WD-40 but no difference. Also it has a rough idle, and runs rough running while moving. Fuel filter new plugs within last year oil etc.. Just trying to figure if its a carb problem before sending it for rebuild..
