Re: stumped
Ok, start with the basics.
1) Check compression in all cylinders. Above 120 should be ok. To do this test, pull all spark plugs, insert compression gauge, open throttle fully and turn over.
2) Do all the spark plugs fire a nice bright blue? Check em out
3) If 1,2 are ok, check the timing. It may be tough if it's not running right, but try to ballpark it. If you move the dist to adjust make sure to mark it before you get going so you can get it back to where it was!
4) If 1,2,3 are ok, then look at the fuel. Have you craked the carb? Look especially for any blockages in the idle and power fuel jets...it's classic to have varnish buildup after sitting a while. Also classic is to have a needle and seat stick open or closed. Also, pull out the float and shake it...any fluid inside? If so, replace it as this will increase your float level.
Basically, fuel, spark, air. It's one of the 3.
Chay
