Welcome Guest - Sign Up today
No announcement yet.
cotter pin on the lower swivel pin
  • cotter pin on the lower swivel pin
    I got a new cotter pin... what is the easyest way to get iot ... it seems the space is smaller then the pin so would have to bend it... any ideas or tricks?
    "Reel Justice"
    Trophy 2059
    Bravo 1 Drive
    Mercruiser 5.7 250hp
    Re: cotter pin on the lower swivel pin
    Half of the old pin may be broke off and still in there?
    '90 Chaparral 2000SL
    5.8 Cobra
    '67 MFG Westfield Regal
    80hp V-4
    (No private messages)
    • #3
      the whole pin came out... it seems like the pin is to long for the space provided to put it in... but it is a merc pin came in the package... I am afraid to bend it s o i dont ruin its integrityy
      "Reel Justice"
      Trophy 2059
      Bravo 1 Drive
      • #4
        I'm not sure I follow what your problem is. What is in the way? The new cotter pin should go through the transom shield and the pin and gets bent over to prevent it from falling out.
        Don S.
        Please, no PM's (Private Messages) regarding boat/engine problems.
        That is what the forums are for.
        Only forum/moderator issues will be answered in PM's.
        • #5
          If itw to long you can cut it off just measure the one you took out and cut the new one the same size.
          • #6
            the bottom side walls of the ring were blocking access to the hole... during both removal and replacement. I had to bend the pin and use some real skinny needle nose pliers but it worked.
            "Reel Justice"
            Trophy 2059
            Bravo 1 Drive
            • #7
              I had the same problem, the side of the ring is too close to where the pin goes in. I turned the ring as far to one side as I could and bent the pin a little bit and got it in there.
              Jason
              '85 Mach 1 2350 Condor W/ Mercruiser 260
              sigpic
