Welcome Guest - Sign Up today
No announcement yet.
Knock Sensor Install - Teflon Tape?
  • Knock Sensor Install - Teflon Tape?
    Quick question about the installation of a new knock sensor. Would it be good practice to wrap a bit of teflon tape on the threads before screwing the knock sensor in?
    1987 Alpha 1 - 2008 efi 5.7 L S/B.
    ON the oppostie side of the engine there is s small brass plug to install. It has tape on it. Wondering if the same for Knock sensor?
    Thanks Roman
    Re: Knock Sensor Install - Teflon Tape?
    It would not be a good practice to use teflon tape on any system in a boat. There are better products. Standard pipe dope with teflon in it is 10000% better than teflon tape.
    TT wil also insulate the ground to sensors of any kind.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      No. There should already be some kind of junk in the threads... usually orange. That's it.
      2000 Chris Craft 240 Bowrider
      5.7L Volvo Penta GSi
      • #4
        That is ONLY if it is a genuine OEM Mercruiser part. Aftermarket manufactures miss that step, along with a few other obvious differences in some parts. How else can they make them cheaper.
        Don S.
        • #5
          EDIT:
          NOT
          • #6
            A knock sensor just screws into the block to detect engine knock, pre ignition. There should be no need for any thread sealant, besides it needs a good ground.
            1978 17' Arrow Glass Cheetah
            Mercruiser 165 hp inline 6
            Mercruiser 888 drive
            sigpic
            • #7
              I seem to remember the service manual indicating specifically to NOT use teflon (or thread sealant) tape on the knock sensor. There's really no reason anyway. You're not sealing anything anyway.
              • #8
                Nothing on the threads.
                Was not even going to post when i saw Ht post, cause he got it right, always does.
                No anti-seize ether.
                Resist the urge to coat every thread with something.
                " The Chief Has spokin "
                1986 Citation 19' 140 merc motor transplanted Sept. 2008. Stringer drive.
                1976 Arrowglass couger, 76 Evindrude 70 hp.
                1970 Aluminum jon boat 3 hp air cooled sears out board
                Be good, be happy, treat people as you would want them to treat you, for tomorrow is promised to no man.
