Howdy Fellas,
I'm needing to pull my engine to deal with an oil leak at the timing cover. Did try the lazy way with gasket maker but it didn't work out. So I gave it a shot doing it the right way, but couldn't get the engine out all the way. Here is what I did do far:
1. Remove battery
2. Disconnect main wiring harness
3. Disconnect power steering lines (what a mess)
4. Disconnect fuel line coming out of fuel tank
5. Disconnect water hose running over the engine from the back of the boat
6. Disconnect throttle and shift cables
7. Removed outdrive
8. Loosen exhaust hose clamps on both sides
9. Removed lag bolts from engine mounts
After looking at some diagrams I think I missed a couple of bolts that mount the engine to the transom in the back. Haven't laid eyes on them yet but looks like they're going to be under a bunch of hydraulic lines and whatnot on the back of the engine.
Other things I think I still have to do before trying again are removing engine grounds which I couldn't find but ought to be there and taking the gear oil reservoir off the front of the engine.
Can you guys give me an idea of where to look for those grounds? Anything else I've missed before trying again?
1. Remove battery
7. Removed outdrive
