johnkom
- Jul 26, 2004
- 163
Replacing the manifolds and risers on my Mercruiser 233 due to a cooling issue. The new risers are BARR and came without the sleeve in the discharge where the water goes into the rubber connector. Old ones had a sleeve in the last 2-3 inches before water entry into the rubber connector. Is that sleeve necessary? I tried to remove the old one by heating it but no luck. Do I need to return these and get different ones?
