warshark25
- Aug 6, 2017
- 17
Hello all I recently purchased a 1994 Sea Ray 220 Signature Series with a mercruiser 5.7. I am having issues with predestination/pinging when in the water anywhere after 1/3 throttle. If I stay under 1/3rd throttle the boat is fine as soon as I try to give it some go it starts pinging like the timing is too advanced. I checked the timing with a light it is a 8* BTC at 750RPM, new AC delco plugs and wires, compression is good 140-155psi between all cylinders. spark plug gap is at .035. New fuel and carb has been rebuilt. Is there a way to check the ignition module or maybe I am not doing to correct procedure to check the timing properly. Thanks for the advice!
