georgeiv11
- Jul 1, 2020
- 2
Hi All,
First forum post ever, hopefully I follow the rules.
I have a 1995 Wellcraft Runabout Sterndrive with a Mercruiser/Chevy V8 350, carburetor, Mechanical fuel pump.
I've used the boat about 7 times this year and it has run flawlessly. I started it on muffs last night and it ran for about 1.5 minutes then died (with a little throttle applied out of gear). Then consecutively ran less and less, because it's run so well this season I'd be surprised if it was a carb issue. I ran it two weeks ago for about 3 hours, started nicely each time and ran well.
The boat does have fuel it in, new plugs last year and new distributor cap. I'm trying to diagnose/go down the right path in diagnosing the issue.
What I think so far is that it is a fuel issue, but would be surprised if it's the fuel pump. The fuel filter is filled with fuel. The ignition lanyard does make the siren sound when the key is in the on position so I don't believe it's the front end for the kill switch but it could possibly be the backend?
What steps/order of steps should I be taking? The boat seems to run if I prime the engine as well, and then dies off.
Thank you all in advance... have a few people counting on me over the 4th so hoping it's fixable.
