Henkelnr1
- Jul 1, 2020
- 1
I have a 2005 Crownlne 270 CR that was running perfect and then quit running all of a sudden while 7 miles off shore. I checked all three EFI fuses on top of the engine and they're good. I replaced the Fuel Pump Relay on top of the engine and still I have no power to the fuel pump. I disconnected the fuel pump wire, put a test light on the red side of the connector, had my wife turn the key to on and I get no power. However, I do have power at the fuel pump relay. I can hear it click on when I turn the key but it isn't sending power from the relay to the pump. I have power at the relay on pin 30 and 87.
The engine serial number is 0W066416
Oil Pressure Switch?
