Mercruiser 140 backfires and pops randomly when accelerating and when above 3000 rpms. Pease Help!
I have a freshly rebuilt 1986 Mercruiser 140 4 cylinder engine (new bearings, pistons, bored cylinders, valve job). The mercarb carburetor has been professionally rebuilt by National Carb. I have the 3 ohm flamethrower coil with a jumper wire running directly from the battery to the (+) terminal of the coil. This is paired with a Pertronix Ignitor installed in my oem Delco distributor.
Now here is the extremely frustrating issue I am having. The engine idles beautifully at around 750 rpms in gear. However, when I accelerate, I get a lot of popping/backfiring from the carb but can move the throttle up and down quickly to get past it but other times it accelerates with zero hesitation and no popping. Then, once I get to around 3k-4k rpms it will randomly pop/backfiring through the carb again and will also experience the rpms going up and down like sudden hits of loss power. Sometimes bringing it back to idle when it pops then going back to 3k-4k it will run smoothly then the popping and power loss comes back.
This has been very upsetting as the engine has been completely gone through. Valve issue? I set them according to TM #10 for the "non-running" scenario. My timing is set a 6* BTDC at 700rpms. I have seen that maybe the shift interrupter could be an issue? Also, I tested the fuel pressure between the pump and carb and got about 4.7-4.8 PSI. Is this too low? Normally popping is due to a lean condition but my spark plugs are black with a dry black powder coating that makes me think it's rich or possibly a weak spark?
I'm really stumped and don't know what to do from here. I don't want to be replacing good parts with good parts. Any help or advice will be greatly appreciated!
Doug
Doug
