goldbeck09
- Apr 23, 2020
- 13
Hey All,
My Power Trim was working before I winterized-- and just went to start the boat up and tested the trim with no luck -- just hearing multiple click click click noises. The trim is currently all the way up, so it is hard to tell if the UP would work. The down definitely does not work.Initially there were multiple clicks, but now I am down to a single click when I press the trim buttons for both up and down.
I have the pump where there is a green, blue, black wire with two solenoids.
Here are the checks I've done so far:
- Main engine starts up
- All electronics on boat start up (radio, fish finders, etc...)
- Kicker motor starts up and tilt/trim works fine, however the electric start is not working here (I don't think this would be related to my PTT issue, but thought I'd mention it as it was working before I winterized as well).
- Tested batteries with a multi-meter and they registered ~12.7 volts ...
I disconnected the PTT from the boat and tested it in on the driveway by hooking up the power trim motor to jumpers and tested the up/down ...seems to work (spit out fluid from each connection)
I replaced both solenoids.
Still just getting 1 single click when pressing up/down trim on boat.
Any thoughts on how else to attack this?
Thanks everyone!
Thanks everyone!
