Hey
tank1949 Can you please list your engine in the first post of your threads. (model,year, serial number)... It's getting annoying having to constantly guess at what you have.... Thanks.
Stainless steel ELBOWS. Excellent product, but Merc stopped producing them shortly after they started. I suspect because they realised that the SS elbows would cripple the sales of replacement cast iron elbows. My previous engine was a 4.3LX with closed cooling, and I fitted a pair of SS elbows that had come off, I think, a 350Magnum. When I sold that engine 12 years later, they were still on and still looking like brand new.
The only caveat is that you don't run them dry. If you do, unbolt them and drop them in the rubbish bin. They do crack when they get too hot...
Not a flaw, deliberate. Due to stainless steel expanding at a higher rate than carbon steel, if the SS elbow had the same attaching design as a cast iron elbow then, as the engine warmed up, the bolt could be stretched or the gasket flattened. Then when the engine cooled the clamping force between the elbow and the manifold would be too low and the gasket would leak.
Chris...
