Recently purchased a 2001 boat with twin Alpha One Gen 2 drives. Changing anodes as routine maintenance. The prop shaft anodes are so corroded they are fused to the outer rim of the prop shaft seal. I got the small retainer bolts out. Can’t pull the anode off.
Question: Is it worth the risk to break them off?
The drives are running fine. No oil leaks. I don’t want to create an issue. Boat is kept on the trailer and in salt water about two weeks of the year.
