meaning you need a new y-pipe / exhaust. while the crank CL is the same, the flywheel housing pattern is the same, you can get both a 153 and a 168 tooth flywheel on either the SBC or BBC.
the mount surfaces are just a tad wider (not enough to matter)
the mount surfaces are about same spacing forward of the flywheel housing pattern. (not enough to matter)
however the SBC deck is 9.045" and the BBC deck height is 9.8". the SBC is about 21" wide at the exhaust ports vs the BBC about 25"......... so your exhaust will need to be addressed.
