how to repair threaded shift cable threads if destroyd removing the cable
Bt Doctur
Here you go 39/64 drill bit ..6094 , 1/4 inch pipe coupling, 1/4 x 18 NPSF tap , Red Loc-Tite.
With 1 hex machined off, the O.D of the sleeve is .619 leaving a .010 press fit. Once installed tap it thru if preferred but only a 5/8ths depth is needed for the shift cable threads
If needed PM me if you want it done
The new coupling
After some machining
Installed
Ayuh,.... another Great work-around to salvage expensive parts,.....
Brought to us by BD,.......
